Ive tried everything to diable the autostick up shift for NAG1 / WA580 in jeep wrangler and no luck in doing that
Anyone who tried it and been able to do it here ? HELP !
You've done this? Transmission - shift general - autostick: set to disable
this is the stock file of the car i coudnt understand how to disable it :banghead:
help please :pray:
i also have beta but it seams what option you have is different from mine
Attachment 81413
Attachment 81414
Attachment 81415
Attachment 81416
Attachment 81417
Attachment 81418
Attachment 81419
Attachment 81420
Attachment 81421
Attachment 81422
Attachment 81424
Attachment 81423
appreciate ur help
Guess this tuning software is not all the same, I don't see the autostick option in yours. My trans section has a lot more options. Beta 4.1.159
Anyone from HP tuner can solve this problem?
Help please
update your version of HP Tuners, and reread your vehicle, the switches will be there. Make sure your settings are to advanced, as well.
EDIT>VIEW>Advanced
If its basic, after selecting advanced you will need to close out and reopen the tune to get the view to show advanced mode.
I tried to disable the autostick wot and auto stick upshift and no use the car still upshiting on its own
i have been having the same problems and more the latest update to put it nicely is shit so hp but something is not correct
I have tried every combination of Auto Stick disabled/enabled. And still will upshift automatically. The only way to prevent the auto upshifts, is to put the vehicle into sport mode if it has the button. And even then, it will upshift after hitting the rev limiter.
Russ Kemp
Guys - you cannot override the TCM limit setting, no matter what you do with the other settings.
The way a MTCM used to be setup, and most of the early 2006 EGS 52 TCMs, was the engine cutoff rpm limit was LOWER than the TCM limit, and the enable auto shift was set to disable. This would mean you hit your engine rpm limit and never shift, you can sit there all day sitting on your rev limit and itll never shift. SOMETIMES if you managed to really bang hard PAST your engine rpm limit you can just touch the TCM limit and it would shift.
If you want to disable autoshift entirely, set your TCM limit rpm about 500rpms HIGHER than your engine rpm limit, and set the TCM limp offset to about 500rpms. This will leave you hitting your engine rpm limit every time with no shift when in Autostick.
i did that 1-2 the gear change on its own but for 2-3 the gear did not changed
Attachment 81902
we must wait , I have send the solution at the tech ,or you can set the sitch at 16 absolute value the switch with winols
