2 Attachment(s)
Very Rich into Boost on 2 BAR. VE numbers below 100. Am i Crazy?
I'm attempting to tune a new setup on my 01 turbo Camaro. LS1, SBE, single turbo.
Car runs just fine within 0-3% error at part throttle. When going into boost it pegs my AFR at 10.0.
If i adjust these numbers in the VE table, it's showing below 100 in boost areas. Am i crazy to think something is up? I've compared this tune to others in the repository. It just doesn't look right. Could it be some transitional fueling issue?
I'm running 1000cc SEP injectors with their data entered, IFR tables adjusted for my flow test readings. I've changed by FPR from referenced to non-referenced and adjusted offsets, thinking maybe i had an issue there. Sort of changing my tail at this point.
Should i just copy/paste the corrections and let it eat? some of my in-boost VE numbers would be in the 80s.
Also...it seems that regardless of what VE numbers I insert after corrections...that error is consistently.
Tune and Log attached. Not that i did not do any smoothing on the tune's VE tables.
Any help is appreciated!
Attachment 102090
Attachment 102089
