foxbody mini stock car, customer built car, Can't get it to run past 6k rpm. Goes into fuel cut mid track. I've Raised fuel cutoff to well above the desired range, set all torque and vehicle speed parameters to 1.0 to disable and can't seem to remove the limiter. Mechanically is maintaining fuel pressure and etc at rpm.
Any advice would be greatly appreciated. Thanks, Luke
