2016 Camaro Fuel pump Voltage
I have a 2016 Camaro 2ss A8 with the zl1 low side in tank fuel pump. I have been seeing where a boost a pump is being installed to increase voltage to increase pressure. I came across an article that stated HP tuners can now increase voltage via tuning. Is this true? If so how and where is this found in HP tuners? Would you be able to command a higher normal voltage then as you go wot raise the peak voltage currently in the stock tune? That way you don't get the fluctuations. Also be able to use zl1 pump more affectivly.
