4l60e WOT torque Management 1 - 2 shift
I'm running a mostly stock 5.3 LH6 with a 4l60e from a 2005 Trailblazer. E40 ECM T42 trans controller. I had the transmission performance rebuilt by a reputable builder so its good for some abuse. I'm trying to firm up and reduce shift times but the WOT first to second shift has a significant torque reduction throttle blade closure that I can't seem to alter. The 2-3 WOT shift has no TM and performs as commanded. I've changed values in all of the transmission torque management tables (including zeroing them out) but it has no effect on the 1-2 WOT shift. Data logs show the throttle blade closing to about 35% and then re-opening, which takes about 400 ms. The logged shift time is between 730 to 750 ms. The throttle blade action is consistent no matter what the values in the TM tables. The commanded time is 350 ms. The 2-3 shift is about 350 ms as commanded. I'm sure I'm just missing a setting or table value somewhere but I cant seem to find it. What am I missing?
