I?m taking a 2014 auto stingray for some pulls was wondering if a 4th gear pull be alright, and where is the abs sensor located so traction control won?t kick in?
i believe through the VCM controls you can turn off traction
but usually only the trac off for several seconds will disable and as you reach your 4th gear it will illuminate the ABS and your good to go.
