GEN IV Oil pressure question?
Ok, I have just rebuilt this L94, TSP Cam had to replace the oil pump when cold it takes a few seconds to build pressure, but goes to 50 Psi. When hot idles between 15 and 20 Psi. When I first start it cold the rockers click for about 3 seconds then quite down. I have installed a manual gauge and pressure is a little higher than the OEM gauge. Is this normal it seems the gauge is lazy but lazy on the Manual also, Now I'm pulling manual oil pressure from the drivers front port on the block. Does this seem normal or should I pull the trans or engine and go threw it to figure out what is going on. The second new pump is building more pressure when cold but I get idle at 700 rpm is between 15 and 20 Psi.
Just looking for a second opinion.
Thanks.
