2 Attachment(s)
LS1fans harnes on 03 suburban
Hi all,
I'm having an odd efan issue.
I set up the ls1fans.com harness and everything appears to be working but the AC fan2 startup.
In Scanner, when I turn on fan 1, fan 1 comes on, same with Fan2.
When I hit my temp settings, both fans come on low.
When I lower my second stage limits and hot those, both fans on high.
When I hit my AC pressure limits, both fans on low and high for state2.
Everything good so far.
But when I am below my AC pressure limits and I turn on my AC, fan 2 doesn't come on.
I can deal with both fans on low and lowering my pressure setting to keep things working, but I would like it to work the way it is intended if for nothing more than my own piece of mind.
I would appreciate any ideas as to what I can test and check here.
Attachment 99762
Attachment 99763
Thanks in advance.
