Quote:
Transmission -> Shift General ================================================== ================
[TCM] 44128 - Manual Shifting Minimum Accelerator Pedal Position for Kickdown: The accelerator pedal must be greater than this for manual shifting to force a kickdown.
Transmission -> Shift Pressures -> Upshift ================================================== ================
[TCM] 40980 - Trans Minimum Desired Line Pressure Normal 1-2: The minimum desired line pressure during a Normal 1-2 shift.
[TCM] 40981 - Trans Minimum Desired Line Pressure Normal 2-3: The minimum desired line pressure during a Normal 2-3 shift.
[TCM] 40982 - Trans Minimum Desired Line Pressure Normal 3-4: The minimum desired line pressure during a Normal 3-4 shift.
[TCM] 40983 - Trans Minimum Desired Line Pressure Normal 4-5: The minimum desired line pressure during a Normal 4-5 shift.
[TCM] 40984 - Trans Minimum Desired Line Pressure Normal 5-6: The minimum desired line pressure during a Normal 5-6 shift.
[TCM] 40985 - Trans Minimum Desired Line Pressure Normal 6-7: The minimum desired line pressure during a Normal 6-7 shift.
[TCM] 40986 - Trans Minimum Desired Line Pressure Normal 7-8: The minimum desired line pressure during a Normal 7-8 shift.
Transmission -> Shift Pressures -> Downshift ================================================== ================
[TCM] 40950 - Trans Minimum Desired Line Pressure Normal 2-1: The minimum desired line pressure during a Normal 2-1 shift.
[TCM] 40953 - Trans Minimum Desired Line Pressure Normal 3-2: The minimum desired line pressure during a Normal 3-2 shift.
[TCM] 40956 - Trans Minimum Desired Line Pressure Normal 4-3: The minimum desired line pressure during a Normal 4-3 shift.
[TCM] 40959 - Trans Minimum Desired Line Pressure Normal 5-4: The minimum desired line pressure during a Normal 5-4 shift.
[TCM] 40962 - Trans Minimum Desired Line Pressure Normal 6-5: The minimum desired line pressure during a Normal 6-5 shift.
[TCM] 40965 - Trans Minimum Desired Line Pressure Normal 7-6: The minimum desired line pressure during a Normal 7-6 shift.
[TCM] 40968 - Trans Minimum Desired Line Pressure Normal 8-7: The minimum desired line pressure during a Normal 8-7 shift.
[TCM] 40970 - Trans Minimum Desired Line Pressure Perf 3-1: The minimum desired line pressure during a Perf 3-1 shift.
[TCM] 40972 - Trans Minimum Desired Line Pressure Perf 4-2: The minimum desired line pressure during a Perf 4-2 shift.
[TCM] 40973 - Trans Minimum Desired Line Pressure Perf 5-1: The minimum desired line pressure during a Perf 5-1 shift.
[TCM] 40974 - Trans Minimum Desired Line Pressure Perf 5-3: The minimum desired line pressure during a Perf 5-3 shift.
[TCM] 40976 - Trans Minimum Desired Line Pressure Perf 6-3: The minimum desired line pressure during a Perf 6-3 shift.
[TCM] 40977 - Trans Minimum Desired Line Pressure Perf 6-4: The minimum desired line pressure during a Perf 6-4 shift.
[TCM] 40978 - Trans Minimum Desired Line Pressure Perf 7-1: The minimum desired line pressure during a Perf 7-1 shift.
[TCM] 40920 - Trans Minimum Desired Line Pressure Perf 7-5: The minimum desired line pressure during a Perf 7-5 shift.
[TCM] 40923 - Trans Minimum Desired Line Pressure Perf 8-2: The minimum desired line pressure during a Perf 8-2 shift.
[TCM] 40926 - Trans Minimum Desired Line Pressure Perf 8-4: The minimum desired line pressure during a Perf 8-4 shift.
[TCM] 40929 - Trans Minimum Desired Line Pressure Perf 8-6: The minimum desired line pressure during a Perf 8-6 shift.
Transmission -> Shift Timing -> General ================================================== ================
[TCM] 30246 - Trans First Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30247 - Trans Second Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30248 - Trans Third Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30249 - Trans Fourth Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30250 - Trans Fifth Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30251 - Trans Sixth Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30252 - Trans Seventh Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30253 - Trans Eighth Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
[TCM] 30255 - Trans Reverse Gear Inertia Mode Delay: When gear engagement mode is used, this is the delay before inertia mode.
Transmission -> Torque Converter -> Pressure ================================================== ================
[TCM] 46919 - TCC Maximum Commanded Pressure: The maximum commanded torque converter clutch pressure.
[TCM] 46920 - TCC Fast Fill Pressure: The desired pressure during fast fill of the torque converter clutch.
[TCM] 46921 - TCC Output Pressure: The output control pressure based on current conditions.
[TCM] 46947 - TCC Pressure Offset For Lock: A pressure offset applied to lock the torque converter clutch.
[TCM] 46932 - TCC Apply Pressure Ramp: The pressure ramp used to apply the torque converter clutch.
[TCM] 46933 - TCC Apply Pressure Ramp First Gear: The pressure ramp used to apply the torque converter clutch for first gear.
[TCM] 46934 - TCC Apply Pressure Ramp Second Gear: The pressure ramp used to apply the torque converter clutch for second gear.
[TCM] 46935 - TCC Apply Pressure Ramp Third Gear: The pressure ramp used to apply the torque converter clutch for third gear.
[TCM] 46940 - TCC Apply Pressure Ramp Eighth Gear: The pressure ramp used to apply the torque converter clutch for eighth gear.
[TCM] 46937 - TCC Apply Pressure Ramp Fifth Gear: The pressure ramp used to apply the torque converter clutch for fifth gear.
[TCM] 46938 - TCC Apply Pressure Ramp Sixth Gear: The pressure ramp used to apply the torque converter clutch for sixth geard.
[TCM] 46939 - TCC Apply Pressure Ramp Seventh Gear: The pressure ramp used to apply the torque converter clutch for seventh gear.
[TCM] 46941 - TCC Apply Pressure Ramp Performance: The pressure ramp used to apply the torque converter clutch for active performance mode.
[TCM] 46946 - TCC Apply Pressure Ramp For Lock: The pressure ramp used to lock the torque converter clutch.
[TCM] 46942 - TCC Release Pressure Ramp: The pressure ramp used to release the torque converter clutch.
[TCM] 46922 - TCC Starting Fill Compensation Pressure: The starting value for fill compensation pressure.
[TCM] 46923 - TCC Starting Fill Compensation Pressure First Gear: The starting value for fill compensation pressure for first gear.
[TCM] 46924 - TCC Starting Fill Compensation Pressure Second Gear: The starting value for fill compensation pressure for second gear.
[TCM] 46925 - TCC Starting Fill Compensation Pressure Third Gear: The starting value for fill compensation pressure for third gear.
[TCM] 46926 - TCC Starting Fill Compensation Pressure Fourth Gear: The starting value for fill compensation pressure for fourth gear.
[TCM] 46927 - TCC Starting Fill Compensation Pressure Fifth Gear: The starting value for fill compensation pressure for fifth gear.
[TCM] 46928 - TCC Starting Fill Compensation Pressure Sixth Gear: The starting value for fill compensation pressure for sixth gear.
[TCM] 46929 - TCC Starting Fill Compensation Pressure Seventh Gear: The starting value for fill compensation pressure for seventh gear.
[TCM] 46930 - TCC Starting Fill Compensation Pressure Eighth Gear: The starting value for fill compensation pressure for eighth gear.
[TCM] 46931 - TCC Starting Fill Compensation Pressure Performance: The starting value for fill compensation pressure for active performance mode.
[TCM] 46943 - TCC Fill Compensation Time: The desired fill compensation time for the torque converter clutch.
[TCM] 46944 - TCC Fill Compensation Time Performance: The desired fill compensation time for the torque converter clutch for active performance mode.
[TCM] 46945 - TCC Fast Fill Time: The desired fast fill time for the torque converter clutch.
Transmission -> Torque Management -> General ================================================== ================
[TCM] 46276 - Torque Management for Gear Monitoring: Master Enable/Disable for torque limitations used for gear monitoring.
[TCM] 46250 - Transmission Maximum Torque Limit by Temperature (Gear 1): Maximum torque limit based on temperature for gear 1.
[TCM] 46251 - Transmission Maximum Torque Limit by Temperature (Gear 2): Maximum torque limit based on temperature for gear 2.
[TCM] 46252 - Transmission Maximum Torque Limit by Temperature (Gear 3): Maximum torque limit based on temperature for gear 3.
[TCM] 46253 - Transmission Maximum Torque Limit by Temperature (Gear 4): Maximum torque limit based on temperature for gear 4.
[TCM] 46263 - Transmission Maximum Torque Limit by Converter Temperature (Gear 5): Maximum torque limit based on converter temperature for gear 5.
[TCM] 46264 - Transmission Maximum Torque Limit by Converter Temperature (Gear 6): Maximum torque limit based on converter temperature for gear 6.
[TCM] 46265 - Transmission Maximum Torque Limit by Converter Temperature (Gear 7): Maximum torque limit based on converter temperature for gear 7.
[TCM] 46266 - Transmission Maximum Torque Limit by Converter Temperature (Gear 8): Maximum torque limit based on converter temperature for gear 8.
[TCM] 46267 - Transmission Maximum Torque Limit by Converter Temperature (Gear Reverse): Maximum torque limit based on converter temperature for reverse gear.
[TCM] 46269 - Maximum Torque Limit Upshift 1-2: The maximum torque allowed during a 1-2 shift.
[TCM] 46270 - Maximum Torque Limit Upshift 2-3: The maximum torque allowed during a 2-3 shift.
[TCM] 46271 - Maximum Torque Limit Upshift 3-4: The maximum torque allowed during a 3-4 shift.
[TCM] 46272 - Maximum Torque Limit Upshift 4-5: The maximum torque allowed during a 4-5 shift.
[TCM] 46273 - Maximum Torque Limit Upshift 5-6: The maximum torque allowed during a 5-6 shift.
[TCM] 46274 - Maximum Torque Limit Upshift 6-7: The maximum torque allowed during a 6-7 shift.
[TCM] 46275 - Maximum Torque Limit Upshift 7-8: The maximum torque allowed during a 7-8 shift.
