2 Attachment(s)
GM E67, changed to 2 bar MAP sensor, can't get MAP reading in VCM Scanner
New to all of this, so please bear with me.
I changed the MAP sensor calibration to 200 kpa, and extended the VVE to 200 kPa. But I can't seem to get any MAP readings in the scanner. What am I doing wrong??
2.4L Ecotec made 340 WHP on a Dynojet with 10 psi and E85. AFR's are in the 11-12 range at higher RPM and about 23* of timing. Idle is a bit wonky but runs pretty good at the moment otherwise.
Logs and tune attached. It was a quick tweak to a stock MAP so the tune is pretty rough but E85 doesn't seem to care.
Can anyone provide any insight??
Thanks.
