Can you disable the key/security (like GM Vats) to swap and run motor on another car?
And use automatic motor with manual trans?.
Hi, I have a tundra 5.7 you can disable the immo? Its posssible ? thanks, Waldo.
What's the answer?
Yes it's possible.
For the immobilizer this requires adding a module to the ECU to bypass the immobilizer.
Attachment 88786
For the transmission this requires wiring in an external A/T emulator module either analog or CAN-bus based depending on the vehicle and transmission.
Attachment 88788
These modules have been made for a limited number of Toyota vehicles. If there is sufficient interest they can be made for any Toyota.
Very cool!
interesting
I believe we can do this, i'm waiting on test results to come back from a diesel customer.
Customer never reported back :shrug:
If you want to test, please create a support ticket.
Ticket made need to disable immobilizer on 2010 Tacoma 4.0
any updates?
