I have one Cadi that needs Theft removal, where should i send stock tune so that can someone see if it is possible ?
best regards
best regards
Bump
Best regards
thats a body function not p/tcm option.
well then how come in LS1 You can disable VATS/PATS in PCM ?
best regards
They use entirely different engine management systems. Unfortunately we do not have a solution for this application.
is there a way to enter vats now i seen the last post was from 2017 im having a similar issue
No, it will never be available for these ecm's.Quote:
