this one is an 06
this one is an 06
If you need an 07 I can provide it. Also GM stage 2 files if you have those injectors.
this is the 42lbhr injector data. file is from a 2005 ss but the injector data tables are identical. just copy and paste
Thanks a ton guys!
cobaltssoverbooster, also, thanks for your LSJ/LNF tuning videos on youtube, very informative!
https://www.youtube.com/watch?v=wsQ1...L5S4trpO6F9OLq
SSKev: If you need an 07 I can provide it. Also GM stage 2 files if you have those injectors.
Highly appreciated!
From: https://forum.hptuners.com/showthrea...SJ-Stock-Tune:
too start out though i would switch the fueling tables and airflow tables to the 07 because its alot more linear and smoother than the 06 file - look at the injector flow and pe tables and you'll understand what i mean
