I have an 05 5.9 I use for pulling. 100% sticks, 65mm charger, 12mm stroker cp3. I am new to this software I would like some input on my tune.Attachment 92337
Transient Rail Pressure table looks stock compared to the density based tables, high speed gov low limit should be raised, and if you're only going to be using the truck for sled pulling then timing looks okay. If you also drive the truck on the street I'd smooth out the rail pressure table and work on timing. Just my 2 cents
