2 Attachment(s)
1996 Camaro LT1 Torqhead 24x swap high idle issues
Can anyone help me out with why my car has a higher idle speed when driving? The car was a 6 speed converted to a 4L60E. I have 24x swapped it prior to changing to the auto and had the car dyno tuned as well. It will only idle around 750 when under 10mph. I tried playing with the throttle cracker tables and enable/disable speeds and nothing seems to make a difference. I have my tune and log file attached. You can't see in the log but I put the car in neutral and costed several times from highway speeds down and it likes to live around 1300-1500 rpm. It's very annoying and over powers braking. I can't stand when it feel's like the car is still giving itself some throttle, when I am at 0% TPS I expect the engine to be running at the lowest RPM possible.
