Greetings!
Is it at all possible to display latitude and longitude in formats other than decimal degrees?
Thanks for your input,
F
Greetings!
F
If you're looking for Degrees Minutes Seconds, then that would be pretty easy to put together a Display Object for that since it's just truncating and multiplying by 60 two times. I can put that together here and upload it for you if you would like it.
UTM seems a bit more complicated. Most of the conversion tools online look like they use libraries to perform the conversion rather than any simple mathematical statements. It could probably be done in a Display Object, but you're probably better off finding a script or excel formula that will perform the conversion for you on your data prior to importing it into RaceRender (or after having RaceRender extract data from a video, exporting the data to a CSV, and then performing the conversions prior to importing it again into RaceRender).
