Since The repository is closed, is it possible to get some stock files here?
It doesn't have the engine side, this file contain only transmission
Is there is any stock file of Golf GTI 2010???
Is there an ETA for 7 speed DQ381 support?
A lot of us are hoping for 1.8 support soon so we can jump ship from Eurodyne. HELP!
#1.8T Lives Matter Too
i have tried to ID MK7 GTI but it only read the DSG not the engine,any clue ?
I had similar issue but other way around. Would read ECU but not TCU. I put in a trouble ticket and support was added in under 24 hrs. I think mine was just a minor version difference and one they hadn't seen before, so it was easy fix.
https://support.hptuners.com/index.php?/Tickets/Submit
Were you able to read the ECU/TCU, or does it identify the part and then provide you with a generic stock file to work with?
Attachment 103553
I will be submiting the info LOG for the Audi TT 2.0TFSI, Audi A4 2.0TFSI and the SEAT Leon 2.0TFSI...hoping you HPT guys can finished the support for then too, because they share the same platform, same engine and same ECU's
Is that just for this platform?
The description of the product: "Connect > Read > Edit > Write > Drive." and that for the support of VW: "Using the latest generation MPVI2 and the feature packed VCM Suite - read, write, and edit your vehicle's calibration wherever you want." gave me the impression it would be able to read the tune.
