also this new beta is nice... we now have transmission controls and other new function that i don't know what they do.. but thats good. but we still cant change the tire ratio, but thats not really a big deal, we can live with out that.
Im able to change it up to 40in tall tires & 7.00 gears do you need to go higher?
worse comes to worse you just lower the gear ratio until your numbers line up using the 40" tall tires as the max height.
here is the error we get when we try to change the gear ratio. i am not sure what we are doing different.
Then you didn't download & install that version 2.2.1 I sent you ;)
It is possible that your P0171 code came as a result of a fouled plug. I have experienced a fouled plug that caused a misfire before which resulted in a lean code on that cylinder bank.
Fouled could also be caused by running rich. You may have the fuel injector flow rate off, resulting in a bad running condition. Usually when running really rich the plugs foul quickly.
so i finally fixed the problem i was having with the hummer.All better now
http://i51.photobucket.com/albums/f3...eez247/003.jpg
http://i51.photobucket.com/albums/f3...eez247/005.jpg
http://i51.photobucket.com/albums/f3...eez247/012.jpg
What in the hell did you do?! I'm having a flash back!
Looks like you got friendly with a new-jersey border.
Im thinkin he went rock crawling and made a wrong turn lol
Being an H3 with that much damage it is a total loss?
Go lower!! Drive slower!!
Really sorry to see that. Ouch !!
That sucks! They seem a lot tougher in the video games :)
BTW (not that it matters now) - on his scans, was I the only one not seeing O2 voltage? Maybe I configured something wrong in the scanner config...
p12 pcm's probably use a different PID than an 02 V8 camaro that the default config was setup for originally.
wow dude, nice.....
howd that happen bro?
i hope ur ok man!!!!!!!!!!
look at his avatar seems about 3 secs from the wreck
I have my tuner and six credits for sale.Only asking 350.00.If interested call me 407 697 3969 name is greg thanks.
Can you upload the tune file i have a problem with a 2006 H3 turbo and i need a turbonetics tune to compare or if you cant send tome the tuning file to my email i apreciate very much [email protected]
i already mentioned you needed to talk to tech in your other thread. every engine setup is different and nobody will have a specific tune for turbonetics in general. you need a lot more information to get a tune that is even remotely close to what you are asking for. i would not expect anyone here to throw you a reliable tune. 90% of the people teach you how to do the work, most never hand it out for free.
please talk to hpt tech to solve your connection issues first.
