2 Attachment(s)
Low Pressure pump control??
I'm clearly doing something wrong, or having issues with my setup. I'm not able to get good control over my low side fuel pump(s).
Setup -
* Stock C7Z pump
* Add-on Weapon-X low side system
* 5 PSI Hobb switch
* No additional FPR for low side pump
* confirmed working by bridging Hobb switch
I'm not dropping low side fuel pressure during the pull, but the issue I'm having is that I'm not able to get it to provide more than 58PSI of low side pressure. In the log/tune attached, it's commanding 87 PSI, but the fuel pressure delivered is unchanged.
Any input on what may be causing this to not react as expected?
