Unfortunately I believe HPTuners currently does not support that vehicle/engine platform. If I were you I would email [email protected] to verify though.Quote:
Originally Posted by radarguy
contact tc at tunercat, he has what you need, I think $389 for first and then 79.99 for each additional definition, No scan tool though,
I don't own a truck but I've stuck my fingers in a
couple other peoples'.
I just ordered 02 Avalanche (bone stock) and
02 Truck. I will be posting #'s shortly after HP arrives.
02 Silverado ECSB 5.3
Borla Catback
Flexalite Monster Fans
K&N filter in stock box
BFG A/T 265
Truck currently makes 245WHP (DynoJet)
countdown is on...........
18 Days and counting.......................................... ....
Just arrived today..................
Chris
2k Silverado 1500 tow truck Whipple at 10 lb,water injector,2600 pro troque stall,jet performance trans with eaton and 4.10
Havent tried tuning yet to many other projects.
Another truck owner ;D
Newby here
Having a 1986 5.7L 400ss TBI, would love to start tunning it so any info would deserv a :cheers:
Regards
Ray
exopar, pull your ecm out, check the service number, most likely is 1227747,
if so then you need the following
tunercat software with $42 definition file (99 bucks total)
eprom programmer/reader (anywhere from 50 to 1000 bucks)
spare eproms (2732a eprom usually wont reprogram) you want the 2732B, or install larger eprom with switch to select which program to use.
some places you should go, www.thirdgen.org , check the diy prom section, www.moates.net , hardware and software , search for tunerpro , similar to tunercat just a lot cheaper.
then of course your going to need a scanner, check into a program called winaldl
that should get you going in the right direction anyway
Quote:
Originally Posted by 12secSS
Is your truck a 5.3 or the 350.I read the early new body styles 5.3 have
false knock in them
I own a 6.0 Chevy Silverado SS. Bought brand new. Year: 2004
Currently following mods:
Added LPG (Liquid Petroleum Gas) system to the car -> because of petrol prices
Future mods:
- SuperCharger (Radix?)
- Exhaust
Pascal
Mine is a 5.3L. I have tuned out all the knock in my truck, when it knocked you could here it. Especially on high loads, but when it was stock it didn't knock much.Quote:
Originally Posted by 1 newbe
keep'em truckin!
I'm here. :P
I am new again! ;D
We traded in our Sierra for a 2002 Silverado 1500HD 4x4 Crew Cab. It is already modded with a Gisbon Exhaust and an AFE stage II intake. I am going to work on getting the LTFT down to a respectable level, then adjust the daily driving shift points. This is going to be a great Tow Vehicle! :cheers:
I should have posted up here a long time ago. I have a 2002 sierra 2500HD crew cab 4x4 with a 6.0L. Whipple supercharger, 3000 stall converter etc. Just got the EIO cable and LC1 wideband. Don't know what the hell i'm doing. Anyone wanna point me in the right direction? My a/f looks ok as far as i can tell, but, my ltrims are out of control. huge numbers like +20 etc.
I'll gladly post up my tune and my log file if someone can tell me how to
It is ok if your LTFT spike to +20 or so, just so long as it is not a dropped frame (-100). The LTFTs will bounce around like that, just set the histogram to display the average LTFTs. If those are within reason, you are fine. If not then the MAF sensor needs to be recalibrated. RedHardSupra has a spreadsheet for that, this works very well in my experience. Also, there is suppose to be another MAF Cal file based on LTFTs, but I have yet to try that out. You can find them on LS1Tech.com. :cheers:
i fixed the ltrims by adjusting the ifr table. looks good now. why did i just spend over $350 for a wideband? I could have just tune my ltrims via ifr table then spend $75 for 3 pulls on the local dyno. oh well. now i have it anyway.
Hey George, you know what I've got. I'm still waiting fome kind of tuner to become available for the hybrid trucks. :-/
Been tuning for 3 years on GM ECM cars with blowers.
Been tuning the 2001 with a blower for a year now ans I just bought
the HPtuners for my 2001 Suburban and the 2005 GMC Sierra will be blowing the Sierra soon.
05 Chevy crew cab Z71 5.3
Flowmaster dual exhaust with an X-pipe
K&N FIPK
Silveraldo SS running gear and brakes with 4.10 gears
33 BFGs
Programmer on the way and will be on the dyno the following day.
As of right now I can not drive over about 80mph because my truck thinks it going 98 and keeps shutting off. Also because of the gear change it confused the computer and disables the ABS. HPT to the rescue..
