PLX SM-AFR wide-band through serial usb
Hi, I'm new to HP tuners, and after seeing the PLX listed in the channels under "serial" decided to give it a try. When I start scanning the vehicle, the channel I added disappears (which I gather from other posts means that it's not reading correctly). I'm able to view my AFR in PLX's scan software so I know the controller and interface are working correctly. Does this wide-band have native HP tuners support and if not, is there anything I can do to get it working? I have the standard HP tuners interface so the 5v output isn't an option. Thanks in advance.
