Hello everyone, how can I include parameters in graphs in the chart x time in my log?
In the basic configuration it does not show RPM, KR, inj duty (%)
Can anyone help me with this?
Anything you wish to log must be present in the main channels list.
I see that RPM is there but it's not populating at the moment. You should remove that channel, then re-poll for supported parameters and add it back into the main channels list. Then add knock retard, injector pulse width avg. Injector duty cycle is a math of the pulse width and will shows up when you add that channel.
Also things like commanded AFR, you can add that channel too.
If something doesn't seem to be working even after adding in the channel, contact support directly so they can look into a possible issue.
thank you.
I'll try to do this
All the best
Hi, I tried this but it did not work...
Then contact support.
