Vats delete on stock vehicle, is starter checks enabled or disabled ?
basically is the checks needed for the bcm to function correctly or
is the starter checks just for the pcm ?
STOCK vehicle, not a swap.
Disable the starter checks as well. That will allow it to start, even if there is a security issue.
Did disable vats and disable starter checks write entire, bcm will not trigger starter.
ANY suggestions ?
2013 van is current one.
