crank sensor not learned - changed to "not reported". question
I have a 2017 viper. It continues to throw a crank sensor not learned P0315 at least 1-2 times out of 10 upon start up. If it starts up ok and no code, the light will not come on while driving. It only does it at start up. The car is a head cam car. The builder tried a new sensor. No difference. I then had the dealer relearn. It still does it. I just use my OBD connector to reset the codes, and light goes off until next time. Car runs fine otherwise.
In my tune, it has P0315 as report on 1st error but no box checked. Will it be a problem if I just set it to "not reported" or would no MIL light be a better option but the code will still show in the scanner? I did some searching but I want to make sure by setting it to "not reporting", it won't effect how the car runs. It just won't show the code in the scanner and light will stop coming on.
Thanks,
Michael
