Hi all,
Trying to make sense of Knock Sensor Cyl outputs. It's given in voltage, which makes sense but the values range from 4-10v when idle/normal throttle, at WOT it's hitting 70v. So obviously it's not actually in volts. There's also a Knock Intensity reading which stays at 0. I'm getting no timing retard so I don't think there's any actual knock but I'd like to be able to interpret this output.
Thanks,
