Need some guidance 06 5.9 cummins auto. stock
So I am new to hp tuners and diesel tuning all together. I just don't know where to start. I have read though a lot of these forums just to get a feel with what needs to be done.
What i have been doing to far is smoothing out the desired fuel pressure map and also main injection pulsewidth map. I have also smoothed the pedal map steady state just a little bit. But I don't know where to go next.
I looked at the timing calculator spread sheet but the desired timing final does not look right. All of then numbers are positive. When I look at my main soi timing map the numbers are way different.
What am I doing wrong and what else should I be making changes on?
