So I'm transfering my TrackAddaict files and video over Wifi, but it will only allow me to do it first and therefore making it the number 1 video. Next I add the gopro footage and that goes to the pip position. Is there a way to switch these videos?
You should be able to select the video at the bottom of the Display Objects (in the bottom right hand corner). Double clicking on it will bring up the Display Object Properties window. From there, you can change the Input with the dropdown to the second video. Following the same steps on the pip Display Object will change that one as well.
