2 Attachment(s)
Car wont start after turbo/injector install. Tried stoich method. TUNE AND LOG inside
2009 G8 GT internally stock engine, auto trans, E38 ecm
I spent the past 2 weekends installing a turbo, and 1000cc injectors. I've researched and found answers on what I thought I had to do in order to get around the 63lb IFR limit. I doubled stoich, halved IFR, and halved IVT table. I've also switched over to the custom 2.5 bar OS because I thought I could use a 3 bar sensor with it but have since reinstalled the stock map sensor and adjusted tune accordingly in order to eliminate that variable in case its causing my starting issues. Car turns over and will run rough for a few seconds before dying if it sits for a while but it wont start back up and run. I've included my base tune file and a log. Any help would be greatly appreciated!
TUNE
Attachment 92615
LOG
Attachment 92616
