2 Attachment(s)
Cam install, idle issue
Really hoping someone can help with this problem I'm having with my 17 camaro SS M6. I installed a new cam/ported heads. I am getting the car remote tuned, and it runs really well, idles perfect. The issue is it can't find the idle when the car is moving and you put it in neutral. The RPM will drop to 300(sometimes stall), bounce to 1200 then idle perfect. If you are sitting still, and rev the engine it'll return to idle perfectly. I have a log and at the beginning of it, you can clearly see what the RPM's are doing.
Wondering if anyone has seen anything of the sort before???
Any help would be appreciated. And hopefully these attachments work.
Attachment 93766
Attachment 93767
make sure you have calibrated both your airflow models and then move to VT
Goat rope garage has a video coming out on this on youtube. I just watched it early on Patreon. Seems to address your issue.
Quote:
Originally Posted by
Poppacapp
Goat Rope is awesome
Agreed!
