New to HPT. Watched a Greg Banish Gen V tuning video and he referenced a MAP/Baro calc for measuring. Can someone explain to me how to setup?
TIA
TIA
I'm assuming so you can dial in your vve table?
Yes. I've done Gen 3/4 in the past with EFLIve. Just new to HPT and the Gen V.
What do you mean MAP/Baro calc? Measured MAP and/or baro or calculated MAP or calculated baro..? That could mean a lot of things.
The Pressure Ratio (MAP/Baro) is a predefined Math parameter in the Scanner. Just be sure you're logging the PID's that are defined in the Math parameter.
Silv: Thanks for help.
