Newb 2015 Sonic RS Tuning
Hey everybody. I'm new here, just got my mpvi2 last week. I have a 2015 Sonic RS Turbo 6 speed. I've been playing with the tuning over the last week, and so far I've gotten it to run a stable 18psi of boost, 6psi more than I hit stock. But as I've been reading online, people mention VE tables for WOT, partial throttle and decel tables, and I can't see any of that!:banghead: The only fuel table that specifies WOT in the description is the power enrichment table, and it appears that GM kind of disabled that from the factory. I don't see any decel or partial throttle tables at all. I have 2 tables that relate to boost, one is injector flow rate vs Pressure Delta, and the other is flow rate vs MAP. The Pressure Delta table is set up from the factory, but not the MAP table...?:confused: I have no clue what the pressure delta table actually means, and it confuses the hell out of me because the kpas in that table are WAAAYYY higher than anywhere else. The only way I've gotten it to run 18psi stable, is not really the correct way. I put a small vacuum tee in the waste gate line, disabled the overboost code in diagnostics once I confirmed that the boost level was stable and the fueling was okay. As far as the fueling, I just let the stock settings handle it. I read that a stock ECU can handle up to 20psi just in case something goes wrong, so I just did that. Anything to help get my newb ass :o off the ground would be much appreciated, thank you.
