Configuration & Histogram Repository
Aight guys as many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
Year
Make
Model
OS
Vin
What the config is for? Idle tuning, SD tuning, MAF tuning, General
If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
If you have custom histograms you'd like to post as well feel free. Same info is needed.
Here's an example
2001
Chevy
Camaro
12202088
2G1FP22G412102986
MAF Tuning/VE Tuning
NOTE: Do not open the .cfg or .hst files with anything but the scanner.
The .cfg (configuration files) go in your:
C:\Program Files\HP Tuners\VCMSuite2 Directory
The .hst (histogram files) go in your:
C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
1 Attachment(s)
Post em up:
Vehicle Application:
Custom PIDs (if applicable)
Histograms
Here's my trans tuning stuff:
Vehicle Application: LS1/LS6/Gen III Trucks
