0411 dies at full throttle.
First of all thanks for all the help on getting my initial tune on the Jet boat figured out, AFR is good, engine runs fanastic!
A new problem developed this weekend and i'm kind of stumped. I can ride around at any rpm and any amount of throttle, but if I hold it at WOT for more than 5-10 seconds, the PCM completely dies. I lose communication with it through HP tuners, I've double checked wiring connections, grounds, battery connections, etc... It first happened friday, and I had to let it sit for 3-4 minutes and It would fire up for about 15 seconds and die again, this wsa repeated for roughly half an hour attempting to make it back to the boat ramp. after reaching the boat ramp, the PCM would not respond, and engine wouldn't fire for over an hour. Saturday morning it fired right up and ran fine, I replaced all relays and checked all connections. Went out saturday afternoon and rode for around 30 minutes, finally punched it to full throttle, and it died, immediately refired it and went about a 1/4 mile or so at 80% throttle, went to WOT and it died yet again. So i loaded it up before it stranded me again on the water. Has anyone else experienced this with an 0411 PCM?
