2007 Ram 1500 4.7 hot and cold idle speeds
Greetings all,
I have a 2007 Ram 1500 4.7L 80k miles on the clock. I've read in other forums that the hot and cold engine idle speeds are able to be tuned. I understand Dodge programmed idle speeds a bit to high for a few years. My truck high idles cold at 1500 rpm then settles down to 650 or so after it warms up, 60 seconds or so, maybe a little more. When the engine is hot it will high idle about 1300 rpm for about the same amount of time, every time its started, regardless of engine temperature. Then it will settle into a normal idle. My question is will the HP Tuner device allow me to set the hot and cold idle speeds? Is there a sample file available for this truck so I can see what can be tuned in the software? I can live with the stock idle speeds but it is annoying. The only reason I'm considering buying the tuner is I can also use it my ATV shop.
