1 Attachment(s)
Here is the method to the madness for "a 160F thermostat". (E67 PCM V8). Other system
Quote:
Originally Posted by
blindsquirrel
If the button is there for the 2-bar then it is not applied. After it's been applied the button goes away.
There's more to it than just the Desired vs ECT table to determine if the fan/relay should be on or off. You have to look at State vs Desired and Output Control vs State to see what a particular number in a given Desired vs ECT cell will make it do - whether that value will command an output pin on or off.
Here is the method to the madness for "a 160F thermostat". (E67 PCM V8). Other systems should be "similar".
