VVE MAP / Baro Pressure Ratio Logging Help
So i am having trouble logging for my VVE table to dial in my tune as i have MAF disabled to dial it in.
Named it Pressure Ratio
My math parameter is [50030.90]/[50032.90]
50030 MAP sensor Unit Pa
50032 Barometric Pressure Unit Pa
My graph is setup as:
EQ Ratio Error [Math] (from lambda & AFR table )
Unit: %
Decimals: 2
Cell Hits: 3
Shading: 20 High 0 Low
Column Axis: Engine speed
Unit: RPM
Row Axis: Pressure Ratio
Unit: (blank)
I have copy and pasted both axis from the VVE table but my cells are all blank when trying to data log. Please HELP!
Also doing this on an ATS-V
