Originally Posted by
dr.mike
Hi all.
I have just finished up a re-flash mod for the new AEM 30-0300 "X-Series" gauges. It swaps out the AEM CAN data format for an OBDII/PID interface that works directly with VCMScanner 3.0.
Basic features.
1. The Lambda data shows up just as if the car was equipped with it from the factory, as PID 0x24 through PID 0x2B.
2. It has been tested with the new 3.0 release of VCMScanner at the full 100Hz ( 10ms ) polling rate.
3. VCMScanner supports its free-air calibration controls.
4. No voltage offset and scaling issues. No analog noise.
5. The gauge is actually designed to produce data at 500Hz. So at the max 100Hz rate, you are getting real data.
I am looking for a couple of beta testers. If you send me your 30-0300 ( just the gauge), I will flash the mod'ed firmware onto it and send it back.
It does need to be wired into the existing OBDII port wiring. But, that's not so bad :) For non-CANBus cars, you will need to use an OBDII splitter cable ; since the OBDII CANBus pins will not be present in the vehicle's connector shell.
PM me, if interested in trying it out.
