I haven't done a case learn in a few years, but my VCM Scanner just has a ON button for the case learn function. No longer BEGIN.
How are we suppose to do the procedure now?
I have the same question. I hit the on button and nothing happens.
This was the process I used (and worked);
using 3.0
Ill try to clear this up for those having trouble...
set park brake,
push and hold brake until you are completely done,start vehicle,
click ( crank learn) fairly quickly accelerate till you hit the cut off, let off throttle once it has come to an idle IF successful your mil will go off,
click the OK button that told you to accell to cutoff,
turn off ignition for atleast 15 second. restart and the mil should stay off
you can now release the brake.. ( i also had to go into the diagnostic menu and clear the code from there on VCM Scanner but after that it should be fully reset.)
I have the newest version and nothing comes up to accel. No instructions or confirmation what so ever. They definitely need to improve this process. Thanks for the help
