5 Attachment(s)
KR for off-idle tip in....concerning?....fix?
Could use some impressions on this little issue. Should I be concerned about these knock spikes? In other logs, they appear equally short, but can be as high as 1.4* KR. They seem to correspond with off-idle tip-in, and with shifts as I watch the TPS move after shifts. Always in the 800-2500rpm range, with 0.3-0.6g/cyl areas. I presume this is related to a lean tip-in with transient fueling. Tune and log are attached.
SD with MAF deleted, OL in these logs. CL doesnt seem to help.
'14 L77, 6L80e, DoD delete, stock rec port heads
BTR PDS stg 2 cam with 122+6 LSA
dual 90mm DBW throttles
6-71 PDS
headers
I have already de-sensitizes the knock sensors to match those of a '13 CTSV, and upped the transient Impact and Evap factors to well over stock. Adjusting the timing doesnt seem to help proportionately.....takes ~10* retarded timing to get the spikes to go away.
Also seem to get them randomly at idle and cruise....those logs also attached. Those logs have STFT and LTFT functioning
any input would be greatly appreciated.
