Ok, I've added this tidbit of information into the beta email I typically send out so that hopefully makes this perfectly clear to anyone receiving the beta from here on out.
I'm having the same problem with a 2016 Escallade right now that we just finished a blower install on. 2.25 scans, 2.24 is missing most pids like knock retard/ MAF freq, etc. 2.24 also thinks it is a 2013 or 2014. Anyway this truck is AWD so I can't put it on the dyno to record WB data and without EIO working on the street I have no way of recording wideband data. Can we get EIO working in beta ASAP or at least open 2.24 back up to do 2015-2016? I'd be very happy with either. Right now I'm dead in the water.
Can we wait till 2.25 is working with bare minimum to shut down 2.24? Pretty please? :)
I have to tune a 2016 ZO6...I've done a 2015 without issue using the 2.24 scanner. If I understand correctly I cannot do this with the 2.24 scanner as it's a 2016 car...so I cannot log the wideband through my EIO?
Does anybody have a workaround? Wonder if I could put a 2015 ECU in the car, scan and tune, then copy everything into the 2016 ECU...
I have tuned a few of the 2016 Z's. I only use the 2.24 scanner for anything. Just change the "SAE MAP" pid to "high resolution MAP" and it should be fine. They show as 2014 Stingray for me.
I'll try that. Thank you.
I wish my solution was that easy. This is a 16 Escalade we just put a blower on.. It's AWD so I really need EIO to record the wideband.
With 2.24
Knock Retard and MAF hz is missing among a lot of others.
With 2.25
no custom pids, no LTFT best I can tell, no EIO logging
The no custom pids really suck because I'll have to average LTFT1, 2, and STFT 1, 2 outside in excel. 4 tables.. uggh.
Attachment 54374
