2 Attachment(s)
Scanner Loading Random Data?
After making a run and stopping the scanning the scanner will automatically save the log file, and the log will also stay active in the scanner, however, if I close the log and load the automatically-saved file, the data between the two are different. They're the exact same file - the just-completed log and the auto-saved file - but for some reason the data is different. Below are screenshots of when I had just completed the run and stopped scanning (first pic) and the same log but loaded a few minutes later (the auto-saved one; second pic). Is this normal? Timing issue of some sort? Same layout, channels, charts, graphs, etc.
For the most part the numbers are similar, but some go from positive to negative or vice versa, or from big to small. I typically adjust my tune based on the just-completed log (what's in the scanner after hit Stop Scanning), but lately I've been going from rich to lean to rich, etc. every time I make an adjustment - just going around in circles (using paste by % - half). Wonder if this is related?
Attachment 128343
Attachment 128344
