2 Attachment(s)
non gm 4 cylinder gen 3 pcm startup issues
so this is off the wall but i have p59 green blue, dbw, ls pcm trying to control a non gm 4cyl. Ive wired it/have all sensors etc in place just like an ls1. i have known good coils/ injectors. i have good fuel pressure. vats is off. the only weird thing i have which i may change at some point is i have a 58x wheel with a lingenfelter box converting the crank trigger to 24x. im getting rpm signal, in fact its almost fired up a few times. the only thing i have noticed out of the ordinary is i can only see with a timing light 1 cylinder firing during cranking. is this normal? i believe its #4 (LS) cylinder thats only firing. i dont have a complete ls car nearby to check that kind of thing right now. ive tried timing/ve changes all over the place just to see if it makes a difference and i cant say for sure one way or another. ive tried MAF and SD and i guess SD got a little better result but never has it started. attached is my tune and my log of it trying to start. the only thing maybe working against me is my battery i have is dipping to 10.5 volts when im trying to start it so im charging it now. No codes that are showing up. any ideas?
