Hi all,
do somebody have a US stock file from a 2018 Camaro 2SS with manual transmission and could probably post it here?
I need to do a swap but thats not possible with the file from repository.
My OS is 12688025
Thank you
Hi all,
My OS is 12688025
Thank you
Attachment 94974
This is a 2017, not sure if it helps
Attachment 94978
your in luck, heres a stock file you need.
Roger
what swap are you doing?
On my own car (EU Camaro 2018 automatic transmission) I did only a system swap to get rid of the 3rd gear problem.
https://forum.hptuners.com/showthrea...esponse-in-3rd
Now I wanted to do this to a friends car who have the same model but with manual transmission.
So I have to do a system swap with an US model.
I found 2 files. One manual (in repository) but with other OS. So I’m not able to do a system swap.
And yours. But I don’t know if this is a manual transmission.
But when I do the system swap with your file then the car won’t start.
This should be what you are looking for.
worked. thanks
Hi,
I hope someone can help us. It goes to this topic with the 3rd gear and OS Swap.
We bought a used 2018 EU AT Camaro and wanted to disable the AFM and 3rd Gear Torque reducution.
Now we saw that some items aren't there were they should be. Checking the OS it looks like someone did swap the OS to get the 3rd gear torque disabled with a different OS.
The OS loaded (12686391) looks like one from a ZL1, where we have an SS. (can someone confirm?)
The OS which should be on the car is 12688025 (compared with my 2018 AT Conv. and a stock file shared here in the Forum from zr1driver).
How could we now get the correct OS on the car again?
Just load a stock file (write entire) ? I thought this is not possible due to the VIN?
Any help would really be appreciated.
Attached a screenshot of the comparison of the Controllers screen.
Attachment 136242
Thank you
Seems like that's the correct OS. Here's a 2018 SS stock file I have for comparison. Same OS as the ZL1 from what I can tell
Yes its a US version, not sure if they're any different. Also not sure you can even flash another OS unless it's a custom one from HP tuners? Which I don't believe there are any for Gen 5. Hopefully someone else chimes in, I'm not at my computer at the moment
thx rabbs88
@zr1driver @robka
Are you able to help?
