On the cobalt ss/sc and Ion Redline could we get a tune parameter to run the fans and heat exchanger water pump after the key is in the off position? Much like we have for fans on LS2's. This would be a nice addition to track days. Thanks, TODD
The parameters are there, but our cars for some reason don't use those settings.
Just put in a relay switch
the key has to be on for the fans to kick on. car has to be running for the ic pump to work
i will look into the ignition off fans settings, the ic pump does not have a ignition off feature.
Chris, does this mean there is no way to controll the pump within the tune?
