2016 JKU Wranger + Sprintex Tuning
Hi all - I own a 2016 wrangler with a sprintex supercharger. The setup is strong at WOT but lacks during most street driving. I only make 1-2PSI at about 10% throttle, and no more boost up until 95% throttle. It doesn't matter which gear or RPM I'm in at all, the boost comes in the same depending on throttle position.
I believe performance enrichment settings are off and there is a fairly unresponsive zone in pedal position preventing boost from building.
Hopefully, I would like to update my tune so that as I tip into the throttle more and more boost builds. Right now I get 1-2PSI, and as I depress the pedal more the trans shifts and eventually I hit WOT and 9PSI. I never see 3-8 PSI.
Any thoughts? My tuner should be arriving shortly.
