Unfortunately, the display object included with RaceRender can run into some issues when dealing with dates at the end of months. I'd highly recommend grabbing the timer rro from this post to avoid those issues:
https://forum.hptuners.com/showthrea...l=1#post608727
To customize it with 24 hour time and timezone, you may need to have either the Advanced or Deluxe Edition of RaceRender (alternatively, I may be able to edit it for you if needed). You'll need to have you'll need to add it to your project and then double click on it to bring up the properties. From there, there should be a big "Open Script Editor" button in the middle of the properties. That will open a second window which allows you to edit some of the characteristics of the object itself including some of the code. Click on the Background Script button in the top left. Then update the appropriate lines:
Code:
TimeZone = 2; // Set the desired UTC timezone here (-8 for Pacific, -7 Mountain, -6 Central, -5 Eastern)
Code:
ShowTimeAmPm = false; // Set to false to use a 24 hour clock
Click OK to save the updates, and you should have what you need!
