411 swapped, now 4L60e swap
Hey guys, I’m new to HP Tuners, and this is my first post.
I have a 1983 K5 Blazer with a 1997 Vortec 5.7, 1983 700r4/NP208.
I did the 411 swap using the Painless harness that was previously running my engine. The Painless harness came pre wired for a 4L60e.
For the 411 swap, I used the Express Van tune to get me started, then cleaned it up, tuned for the cam, etc.
I now want to go 4L60e. I?ve been reading up on the 3 main styles of 4L60e and haven?t come up with much as far as controlling the thing.
Finally, my question:
Which 4L60e do I need? I would like to run the 2 piece case with 6 bolt out put as it is has a beefier housing and is readily available pretty much on every corner.
Will my 411 run it basically plug and play once I add the VSS?
Anything with PWM for the TCC to think about?
Adapters to bolt up the flywheel/converter?
It sounds like all the bell housings will bolt up provided I have the correct flywheel and converter.
Sorry to post such a long winded first go at it.
