Excellent.
Excellent.
I'm working on 2015 F150 3.5L Ecoboost, trying to do tire change. Followed all these threads and using 2.25 Beta, but tire/axle changes have no effect on speedo. I don't see the "Use VID" switch shown above, also only have "N/V base". Is there a VID switch needed?
The 2015 is handled differently and it cannot be changed via the calibration currently.
My 2010 V10 calibration for speedometer is funny. The only thing I have under the table is VSS counts per mile (currently says 670 - which would call the tires 30" tires and the stockers are much bigger).
I cant seem to change the speedometer on a 2015 F-150. Is this calibration available for this truck yet?
Eric, I must be crazy, but my speedo does read different and the car shifts different when I change N/V to 43 and change to Enabled with the specific tire height and rear gear in all the cells.
Can anyone confirm if this is true? Will disabling the VID also cause Select Shift to stop working?
I recently did a gear/tire calibration on a 2012 F-150 5.0L by setting Used Vid to "Disable" and Use Tire Circ. and Use Final Ratio to "Enable" and the customer now complains of Select Shift no longer working.
When you flash it the first time it goes away. Bump the plus sign on the shifter in drive or park and it comes back on and stays on until flashed again. I had this same issue with a customers truck. 15 f150.
I still can't change the speedometer on a 15 f-150. Is this still an issue?
Can anyone confirm if speedometer calibration is working on 2015+ Mustangs?
I am still working on this.
I am about to do a lift on my 2016 F150 Ecoboost. Is it possibility to correct tire size on it yet?
