Wideband and HP tuners not matching
OK, guys, I have an Aeroforce dual wideband system and the gauge seems to be reading right but HP Tuner seems to be reading a little high for example if the gauges are reading 14.56 the scanner is reading 14.75 these numbers are just examples not set numbers. I have the gauge set up just like they want you to set it up 2 in the slope and 10 as the intercept values in the gauge and 0.5 and 10 in the scale in HP Tuners scanner and like I said I think the gauge is reading right but HP tuners is reading high not low like most wideband do when you have a ground offset. so is there a way for me to find out what my ground offset really is and to make sure the gauge and HP tuners are reading the same and reading what it really should be if there is anyone out there that has a dual Aeroforce wideband system that can help me get this set up right or anyone that can help me I would really appreciate it.
Thanks!
Royce
