1 Attachment(s)
Power cutting at high rpm
Hi
Can someone please take a look at this file and let me know where I am going wrong please?
No matter what i do i cannot make it run over 15psi of boost without cutting and jerking at about 5000rpm.
This tune made 350kw at about 15psi of boost, but as soon as i raise the desired boost duty it will cut at high rpm, if i raise it a bit more it will cut in mid range.
Really lost on what to do from now. I would like to get 375kw out of this setup. not sure what is causing this! want to go to e85 later also.
Attachment 55059
Cheers
